Siemens project file system > reference data
Jsmit
Aug 2006
Alblasserdam
18
Hi All,
I'm writing an application to automate checking of design standards in Siemens Step7 programs, now I have found a way to open the symbol list directly into C# but was wondering if someone has more information regarding the rest of the project file system layout... Especially the different views on reference data, I know I can export them but rather have single project selection and let my program do the rest. This also applies to the actual code, anyone of you guru's have an idea of how this is actually stored and linked together in the file/db system behind Simatic Manager? Help is very much appreciated!!!
Best regards,
Joel
Sorry for the expression, F*k. You doing design standards checking for Siemens S7, and you come for advice to one ill informed on the subject.
We, in SA, solve plant production problems, not standard problems.
Haha!!! Well doing that too but in time left I am in charge of checking code of my engineers to ensure quality standards are properly used in the program to avoid programming errors... Since the number of engineers and projects is ever growing I find it more and more difficult to check every line of code myself by hand 4-5 times during a project... So automating this action is not a very bad idea... In fact I already have a tool working only it takes in 6 different files which all need to be generated by Simatic Manager separately.
Just trying to make my life ever easier ;-)...
Best regards,
Joel...
I don’t have the original project file from a Siemens ET200SP. The program is still running on the PLC. Is there any way I can upload the...
1,653
Anyone know of a way to enable smartserver on a TP1500 comfort without having to have the original project file? I don't even get the remote tab...
1,835
Hi everyone! I have a question for the Siemens Step7 gurus out there. But first, some background! There's also a TL;DR at bottom if you don't...
5,988
I have been working on a file in S7 1200 software configuring a comfort panel. I last worked on this file last night and this morning, the...
8,227
What does a siemens step 7 saved plc program project end with for example project1.xxx what are the last three letters?
5,970
