Siemens Question: Prev Cycle Time is 1500 CPU
userxyz
May 2002
any
2,768
In OB1 there is no Prev Cycle time anymore.
Is there a solution to have something like this ?
Or do I have to substract the previous clock read from the current to achieve this ?
Thanks,
Combo
There is a better way. Check out the RT_INFO instruction. It can be called with a number of different modes, to give you the cycle time for OB1 or the execution time of any other OB, as well as the time spent on communications processing.
Look under Extended Instructions-> Diagnostics
OK. You guys helped me out a bunch with my first Siemens question. I found a bunch of issues with integrity checking the PLC programs I was...
331
Does anyone know why my one string is displaying this way? It is causing issues with my HMI displaying it.
269
Hello all. I have an ESA HMI that is connected to a Simatic S7-300 (CPU312). I have uploaded the program from the PLC which is written with Step7...
1,451
Everyone, i am in the process of purchasing the Slc 500 version of software to support what we have and i have a question. Several of our...
775
We've got very fast machine whose position controlled by interrupt OB35 set at 2ms. For position reading we use Temposonic connected to TM...
19
2,520
