Siemens S5-95U connection cable
mxkid98
Dec 2005
Virginia
19
German-made machine has S5-95u processor. I need to download its program to my laptop, but don't have the correct cable. I've been told that I need the 6ES5734-1BD20 pc/tty converter, which I think is a 25-pin to 15-pin configuration. I've seen some threads that have a PC/TTY converter, but the one I've seen has an AG/TTY label...but same part number. Is there a differrence?
The PC/TTY converter is an RS232-20mA current loop converter. Siemens PGs (Programmier Geräte) have the current loop converter built-in and use some free pins on a 25 pin RS232 connector. Never use the AG/TTY cable on a PC, it won't work. Normally it shouldn't damage anything either.
Kind regards,
Thanks for the info on the AG/TTY cable. We have that cable here...but not the PC/TTY. The real problem here is the recent layoff of most of our R&D Engineers, who had most, if not all of the machine programs and interface cables to the processors. This seems to be the case here...engineer is gone...so are the items I need! I have heard that there may be a Siemens PG floating around in the vacant R&D offices though!
we use the Black Box RS232 <-> CL converters. A standard 9 pin to 25 pin serial cable is connected to the RS232c end of the converter, then a 15Pin cable is fabricated to attach to the CL end of the converter which has screw connections.
Ian Phillips
flomation engineering
Hi there! This is something so old and having machine with it....... Last time unit was powered around 3yr ago and it did not work since than...
245
the steps to have a backup from the plc siemens Simatic s5 95u?
2,407
Hello, Dear Friends.I have an Simatic S5-95U PLC,How to upload program from this?. i have PC to TTY cable also and step 5 software too. please...
4,619
Hi, Dear Friends. I have one Siemens S5-95U PLC with EPROM installed in it, i am unable to upload program from the PLC although i have STEP5...
6,231
Hi, I have a machine with a S5-95U plc......with a problem. Last week we had a fault in an inverter unit, which melted some cables in the panel...
2,235
