Siemens S5-95U software
Jezz
Dec 2002
Kendal
399
Hi we have a siemens S5-95U and we are after software to program it now do we need step 5 (I've only found a dos version of this) or can I use step 7 .
Thanks Jezz :(
I didn't found support from Step7. I have used some Step5 dos version in WinNt4.0, but someones have told it isn't work in oneline. It emulates CPM in Dos etc... and CommPort maybe not works.
The latest version of Step5 (V7.2) supports all Windows operating systems, including XP. It actually runs in a DOS window/emulator. The port on the PLC is current loop so you need a converter. The Siemens cable you'll need is a 6ES5 734-1BD20, it doesn't need an external power supply.
Regards,
Rob
Does anyone know where I can download a Step5 manual I've tried the Siemens-industry site but I can't find it..........Help please bonkhead
banghead
Thanks Jezz
Hi there! This is something so old and having machine with it....... Last time unit was powered around 3yr ago and it did not work since than...
240
the steps to have a backup from the plc siemens Simatic s5 95u?
2,406
Hello, Dear Friends.I have an Simatic S5-95U PLC,How to upload program from this?. i have PC to TTY cable also and step 5 software too. please...
4,608
Hi, Dear Friends. I have one Siemens S5-95U PLC with EPROM installed in it, i am unable to upload program from the PLC although i have STEP5...
6,226
Hi, I have a machine with a S5-95U plc......with a problem. Last week we had a fault in an inverter unit, which melted some cables in the panel...
2,230
