Siemens S5 programming
Shawn Cassidy
Mar 2004
Montreal
98
Is there anyone out there with Siemens S5-100U cpu100 programming experiance. I'm using Step5 v7.23 ... Just need to know some of the programming basics. I need to upload the existing program from the PLC. Remove the Eprom then reload the program with a minor change. I realise I need to burn the Eprom using a burner so I want to run the PLC on the ram with battery back-up (no Eprom). Once the program is working I'll have an Eprom burned by my Siemens supplier. I've never used the software and I'm having some problems understanding this software. I work mostly with Omron, AB and Mitsubishi.
You need the manual for that version of STEP5 and I hope you can find it here . I'm not sure if it is already there because it's a very recent version, but the info for versions 7.0 and up would also be useable.
You'll see that the learning curve for Siemens is steeper than for AB, but hang on. Good luck with it.
Kind regards,
Hello,
Since the manual search is temporaly unavailable I'll try to get you started.
When you start up Step5 you see the main menu.
 Select 'PROJECT' enter
then select 'SET' enter
Now you can see allot of tabs first select PLC
After 'MODE' should be OFFLINE
Push 'F3' and now it must change to ONLINE assuming
you have connected your PLC with your PG.
Also check if your interface is AS511
In the second tab 'BLOCKS' give in your Program name
something like [email protected] (only 6 digits)
enter Now you gave your program a name and your PG is
connected to your PLC
Go back to the main menu 'esc'
Select 'FILE' enter
then select 'BLOCKS' enter
then select 'TRANSFER' enter
Select from where to where you want to transfer
First vink on PLC (transfer from)
Then vink on Programfile (and selct the file you
just have made ([email protected])
Then in Blocklist give in the
letter 'B' which means tranfer all blocks.
now you have downloaded your PLC program From the PLC to
your PG
If you want to change your program dothe following
Choose 'EDITOR' in the main menu and enter
then select STEP5 BLOCK (F1)
now you can select your block you want to modify
Source is your file (not your PLC)
select in ' BLOCKLIST' for example 'OB1' and enter
now you can see your OB1
You can switch between ladder or logic or AWL with
Hello,
Select 'FILE' enter
your PG
To download your program back into your plc just do the
it the way around.
Functionkey SCHIFT F5.
Explaining how to modify your program you have to figure out
yourself it would take us to far.
If you should have some more questions please feel free to ask.
Rudi
Thanks for the info guys. I'll be giving this a try on Friday afternoon. If all goes well I should have a good week-end... I got a copy of the manual with the software package but it is very different from the softwares I'm used to. I'll go over the instructions and make sure I fully understand the procedures. Thanks for all your help.
Thanks again for the help guys. Everything went well.
I'm looking forward to the Step7 software though... looks a little more user friendly than the Step5.
100U: Using EPROMS
If you use an EEPROM module in stead of an EPROM, you don't need an EPROM programming device; you can burn it by holding down the copy switch on the front of the PLC.
Hi all, i am the new controls guy at the plant and i have inherited a pc from the previous controls guy with Siemens tia portal version 16 and 17...
20
948
Hey everyone, I am looking for a version of siemens software to upload and download programs to an S5. I would like a version that runs off of...
499
Hi, There's a problem I face with upgrading the OS from XP which has the Step 7 Lite installed to windows 10. As I can't use a cracked version of...
633
I have a customer who had a faulty Siemens OP7. They sourced a replacement. They have the original program. I downloaded the program to the...
2,545
Hi there, I have three pumps, I have to start first pump for 8 minute and after that it should be turned off and other one start simultaneously...
1,868
