Siemens S5 RS232 adapter
glpdrumerx
Oct 2006
Tennessee
48
Hello everyone, we still have many PC's with siemens S5 running in our facility. None of our new laptops have a serial port. Has anyone had any luck with a USB to serial adapter that will work with Siemens S5 software.
Yes, i use the typical converter USB-Serial. The only thing that I notice is that must be the one that use "USB profilic drivers" (something like that in the device manager), her other generic one didn't work.
The "prolific" converter I used with S5, S7 and allen-bradley.
Its hit and miss... but it also depends on the software, if you use Step5 or an after market
I have switched to S 5 for Windows and do not have any issues using a Keyspan adapters and have used Step5 with it... that said I have had a customer try it and we tried MANY different options/settings and did not have any luck and gave up, but same PC and PLC with S5 for Windows worked perfect.
The local connection tab, in Set PG/PC interface doesn't appear in PC Adapter MPI and in PC Adapter Profibus. It only works with usb pc Adapters...
2,029
I'm trying to download a Siemens Protool project into a OP17 with USB to RS232 adapter. The download is starting but it interrupts at approx. 80%...
6,676
Hi i have Beckhoff (CX5020-0120-M310) (profibus master) with TC3.1 and want communicate with Siemens Profibus ET 200S (IM151) DPV1. All modules...
1,703
HI All, does anyone know if you have to change a cp 341 rs232 and use a cp341 rs485, what changes have to be made to get it to...
1,349
Having an issue in which trying to communicate via modbus on an ACM+. I made the redundant serial cable myself, and verified it with my...
2,427
