siemens s7-200 and TC65 GSM modem
ason
Oct 2005
Home
317
Hey i wonder if anyone can help me with this,
i use a TC65 modem with a s7-226 cpu and use siemens SET5
https://support.automation.siemens....lib.csinfo&lang=en&objid=21063345&caller=view
to send SMS
and now i need to send a command so i know if the modem have connection to the network, going to do that every 1minute or so,
was asking that to siemens support and the told me this
"I’m sorry, we’ve no example for that. You can send “at+creg?” with STR_CPY to VB1796. With a block RCV you can save the answer of the modem to a value . What answers you can get you can find here:
http://www.nobbi.com/atgsm.htm#+creg
“1” means your modem is logged in. I’m sorry, I only know this German site."
and i don't know how to use str_cpy and block rcv, any one that can put me in the right direction?
Hi all, Currently having trouble getting a speed reference to write over modbus to an Omron M1... I can successfully write a run command and...
283
commentaire communiqué siemens s7-1200 avec vfd delta ? (cablage et sur tia portal )
148
Hi, I have a 1214 on ip 192.168.0.100. This is connected to other modules through a switch on same network. I need to connect this to a company...
193
Hi Experts, I would like to make firmware upgrade from v3.0 to v4.5 (S7-1200 CPU 1215C). Can I do it from v3.0 to v4.5? Do I need to take some...
320
Hi Guys, I am trying to establish communication over profinet between Siemens S7-1200 PLC as IO device and codesys plc as IO controller. But I am...
43
2,961
