Siemens S7-200 & Danfoss VLT2800
Well Trying Hard, not as such but what VLT2800 do you have.
If you look at the type code there will be an F somewhere in the last part.
F00 is without Fieldbus
F10 is with Profibus DP 3 Mbit/s
F12 is with Profibus DP 12 Mbit7s
F30 is with DeviceNet
VLT2800 F00 will have ModbusRTU, Metasys N2 and FC-protocol (Danfoss own protocol)
And what RS485 is the Siemens Communication port capable of doing?
Best regards,
Michal_DK
Hi all, Quoting a system which calls for a Siemens S7-1200 and a Danfoss FC280. Cost-wise, it's much the same whether I use a higher-spec PLC...
4,247
Hi all, Currently having trouble getting a speed reference to write over modbus to an Omron M1... I can successfully write a run command and...
261
commentaire communiqué siemens s7-1200 avec vfd delta ? (cablage et sur tia portal )
142
Hi, I have a 1214 on ip 192.168.0.100. This is connected to other modules through a switch on same network. I need to connect this to a company...
187
Hi Experts, I would like to make firmware upgrade from v3.0 to v4.5 (S7-1200 CPU 1215C). Can I do it from v3.0 to v4.5? Do I need to take some...
301
