Siemens S7-315 and Red Lion Data Station Plus
r_mclinn
May 2013
Wichita, KS
Hello all,
I am trying to setup a Red Lion Data Station Plus (DSPLE000) protocol converter to communicate between a Siemens S7 315-2PN/DP (6ES7 315-2FJ14-0AB0 profinet) and a Fanuc robot(Ethernet I/P). I have instructions on how to setup the Red Lion unit in Step 7, but I am using TIA portal v13. Has anyone used this unit with TIA portal? I have downloaded a GSD file for the Red Lion unit and imported it into TIA portal which requires the network to be setup as Profibus. Everything appears to compile correctly but I still have ugly red LED's flashing at me from the Siemens plc. I am fairly new with TIA portal so any help would be appreciated. Thanks guys!
Robert
If the Red Lion unit came in as Profibus instead of Profinet, then either you installed the wrong file, or you looked in the wrong place in the catalog.
For Profinet, the file extension should be GSDML, not GSD. Its basically the same thing, just in an xml format. People commonly refer to a GSDML file as a GSD file, but they are technically two different things.
Thank you MK42, I downloaded the GSD file from Red Lion, it appears to be a generic file because it works with the G3 touchscreens the Data Station Plus and also their Modular Controller package. I looked at it and it is definitely a GSD format, but it is the only one Red Lion lists. There is a selection in the configuration software (Crimson 3) for a Siemens S7300/400 protocol but if I choose this option I cannot insert it into my project tree. The GSD file at least allows me to install it as a generic device. The rest of the system is profinet but I was hoping I could use profibus for this device. It will be the only device on the profibus network. Thank you for taking time to respond.
I have an old Siemens TI 505 PLC that works fine. I am looking to add and HMI for system information. I already have a Red Lion G315 that has...
4,905
hello, All LED's on Siemens PLC(CPU 315-2 PN/DP)are blinking continiously & program is not getting downloaded in PLC.i try to format MMC card but...
8,859
Dear all, I am using Siemens S7-300 for the first time. The CPU is 315-2PN/DP. That CPU is showing LED BF1 always on. Can anybody help me to get...
3,041
I'll preface this by saying this is the first time I've worked on a Siemens system and I'm fairly unfamiliar with them. I might mess up some of...
29
751
Hi We were having a few power cuts and the CPU would not work. I had to reset the memory and he CPU would read from the memory card and start...
3,165
