Siemens S7 317 CPU diagnostics help
usedplcs
Nov 2010
Kent, England
36
Hi All,
Was called to a Siemens S7 PLC today in stop mode.
Both Profibus & Ethernet module showing BF.
Run to Stop to Start didn't restart the CPU.
I took a CPU diagnostics dump.
Powered off and back on all came up running fine.
Looking at the diagnostics you run by incomming event time rather than event.
Events run 1-100
Time from 07:46 - 09:13
I have added some comments in Red and think it might be caused by the CP343-1 card but am open to suggestions from the more experienced.
Many Thanks in advance.
Dear sirs, Currently i am working on a project which requires to connect the plc ethernet port to monitoring devices, for your information the...
8,022
hello I need your help, as I can compress the program and send it to CPU 317 - 2DP from Siemens STEP 7, I have damaged the memory card and the CPU...
2,818
I almost have a complete, basic setup for a shop/learning fixture. I've got a used CPU317-2 DP, a G120C, and some purple hose. I'd like to add...
20
5,405
Dear Experts I have three Siemens master 317-2 PN/DP Plc i want to do communication between them which is the best way to do it i am using...
4,167
Dear all, i am communicating between siemens and mistubishi plc using profibus. master 317-pn/dp slave mistubishi q02 please if any one...
2,680
