Siemens S7 331
garryt1
Jun 2002
n.ireland
128
I need to change the input type on an analogue card 6es7 331 7fk02 oabo, can anyone tell me can i remove the card to change the pin set up without faulting the cpu ??
many thanks..
Garry.
You will need to power down,remove the module and alter the jumper on the side.
I wouldn't remove it live even if you have OB's handling the rack failure.
I have never had the pleasure of working with a "Thermistor" until now and have a question. The Thermistor is a 10KOhm 4-20mA 2-wire device and I...
57
Hi all, i have a problem with the above card, my rack has two of them and the same issues! In Channel 0 and 1 on both cards i have 2 wire...
1,910
I've been fighting a problem with this 8 channel analog input card mentioned in the title. I believe it's something I'm doing in the wiring but...
1,722
Hello Experts, I need your help about this issue of mine about my Siemens Analog Input Card SM331 having SF LED lit. I know this is system fault...
4,502
Hello All, Want to know what should be the correct setting for the Measuring range for connecting this instruments to my AI Card? So I am...
2,403
