Siemens AI Card SM331 - Measuring Range Setting
DenZ_P
Jun 2016
SomeWhere
64
Hello All,
Want to know what should be the correct setting for the Measuring range for connecting this instruments to my AI Card?
So I am reading the manual of SM331 AI Card. And it says that i have set the Measuring range according to my inputs. Please see below images.
This is the side of the AI Card:
Now, the SM331 which will be wired like the attach picture named "FCV504B connection" you can see there is a transducer connected to the AI which is PR Electronics 9107B, as per looking at its manual it says it is powering up 2-Wire supply.
So I set it the AI Card Channel 1 and 2 to "D" position. Now I want to know for the attach image "FT16" should I set the measuring range to "C" position as 4-wire? Is this correct? And for the image attach PT24 is this correct to set it up to "D" Position as 2-wire?
Please help! Thanks! 🤞🏻
Hello Experts, I need your help about this issue of mine about my Siemens Analog Input Card SM331 having SF LED lit. I know this is system fault...
4,491
Hey guys! I have come across an unique issue. Hoping that I can find some solution here. I want to replace an existing S7-1214 DC/DC/DC plc with...
4,685
Dear, I came across an analog card from SIEMENS to be used for transferring analog signals. I couldn't understanding the cable length included...
1,073
Hi We had a faulty DO card giving SF error in our Siemens PLC setup model 326-2BF01-0AB0 and we replaced this 326-2BF41-0AB0 I/O card. We updated...
2,027
Hello, we have a 4 wire analyser transmitter (Mettler toledo M300 single channel measuring PH) two wires are for the 24VDC power supply and 2...
1,274
