Siemens S7-400 Ethernet Card
jimdi4
Aug 2004
108
Hello Again,
I need to get my hands on a jpg or pdf file that shows what Siemens Industrial ethernet card looks like .
Card pt number is : 6GK-443-1EX11-0XE0.
I have the quick start CD; Hardware requirenments that shows this module assigned to slot 4 but do4esn't show what the module looks like...Thanks in advance :D
jimdi4
I can't find a picture of a CP443-1, but I can tell you that is the same size as your CPU 416-2, it also occupies 1 slot. It has a run/stop switch and some pretty lights that flash when the CP is communicating. The RJ45 socket is housed behind a nice cover.
Hope that gives you some idea.
Paul
P.S If you really need a picture of one, I have one installed in my test rack in my office at work. I could always take a photo and post it here.
We want connect our application to a Siemens S7 400 by using an OPC server. We tried the Kepware and the Applicom Direct-Link OPS servers that are...
10,903
Hi, Yesterday, I was at a customer site. I made one little change. Changed a dummy bool output to an actual output. I didn't add any tags, or...
348
Hi everyone, I'm working on a project where I need to exchange data between a Siemens S7-1200 PLC and an Allen-Bradley MicroLogix 1400 PLC. The...
674
Good Afternoon. I am having a problem going online with S7-400. Attached is the error that I am getting. I have looked at the help file but the...
1,788
I can't replace cpu S400 416-3XR05-0AB0 BY 416-3ER05-0AB0 in PCS7 Project when using replace object to keep the original configuration in the...
1,509
