Siemens S7 data block - String
SAFE
Aug 2005
Osman
I am trying to access stings in Data Blocks with OPC. However I can access only a few of the DB. For example I can access DB 20 and DB 28 but not 19. What is the reason? Do datablocks differ from each other when the topic is strings?
Thank you.
Hello all, PLC-programming noob here. I have multiple clients accessing some data on my Siemens S7 1211C PLC; some OPC clients and some direct...
30
8,372
Hello all, Newbie in Siemens, I want to ask if there will be any issue when I download the instance datablock of a certain Function block? Also...
4,438
Just a quick question I can't find an answer on yet. I have created my own recipe structure using a Global DB and when I came in this morning...
2,027
Hello, I am trying to find an easy way to create data blocks in Step 7 with ~100K tags other than manually defining each tag in the LAD/STL/FDB...
14,228
Hello All, Is there a way in Step 7 5.5 SIMATIC Manager to export a data block so that it can be imported into another project with all...
3,744
