siemens S7 high speed counters
mark_221
Guest
M
Please help me !!! I am currently using a Siemens PLC the CPU is a 312C and i have a 100 pulse encoder wired into the 2 high speed inputs.
I wish to count the pulses in the program so my conveyor can stop at different positions but what logic do i require to make the counters work accuratley enough any suggestions please.
Try SFB47
Look in the Step 7 standard Libraries under system function blocks for SFB47 "COUNT". Highlight it and press F1 to get the help info and see if this is what you need. You will also need to go into the Hardware Configuration and setup the count portion of the CPU for counting. I haven't actually used these for counting but I have set them up similarly for measuring Frequency with SFB48 and noticed that there is a fair amount of configuration options under the Hardware Configuration.
Hi everyone, I am having some trouble with this counter and programming it correctly. The machine it is installed onto I believe this counter is...
3,023
Hello, Maybe topic does not describe the best what do I want but I will try to explain it now. I'll post this to HARDWARE and SOFTWARE section...
2,493
Hello all I am working on a project where we want to log data on a "high" frequency. Our setup; 1516-3 PN/DP - Tia portal V13 professional -...
11,862
Hello PLC Masters, I am looking for help in HSC module in S5. Now i am making conversion from Siemens S5 to Bradley and previus programmer use...
2,520
Hi, I am currently using a Siemens Simatic S7 313 PLC with built in high speed counters. The issue I have is that the counter appears to increase...
4,608
