Siemens S7 Step7
Loader
Apr 2008
Hjemme
When I try to open a FB-block i got this message:The optional package S7-Scl is not installed..............
Version:S7_BAS_K05.04
Please HELP.....
optional package SCL
I need help finding the optional package SCL
Siemens support-site?I didn"t find it.
Need a link please......
Hello Loader;
You will need to buy an add-on license for S7-SCL:
6ES7811-1CC05-0YA5
SIMATIC S7, S7-SCL V5.3 FLOATING LICENSE FOR 1 USER E-SW, SW AND DOCU. ON CD, LICENSE KEY ON FD, CLASS A, 5 LANGUAGES (G,E,F,I,S), AS OF STEP 7 V5.3 WIN2000PROF/XPPROF, REFERENCE-HW: S7-300/400, C7
Or you might buy an upgrade license to Step 7 Professional, which includes SCL (along with PLCSim, a Step 7 simulator, and S7-Graph, a state machine programming language):
6ES7810-5CC10-0YC5
SIMATIC S7, STEP7 PROF ED2006 POWERPACK (CHANGEOVER PACKAGE) FROM STEP7 V3.X ... V.5.4 TO STEP7 PROF ED2006, FLOATING LICENSE FOR 1 USER, E-SW, SW AND DOCU. ON DVD, LICENSE KEY ON USB STICK , CLASS A, 5 LANGUAGES (GE,EN,FR,IT,SP), EXECUTABLE UNDER WIN2000PROF/XPPROF, REFERENCE-HW: S7-300/400, C7
Ask your Siemens Rep.
Hope this helps,
Daniel Chartier
Hi all
Thanks much for the info--
Loader
You do have the SCL source code, don't you ? Without it, the SCL compiler is as much use as a chocolate fireguard !
SCL is a wonderful package and is worth every penny. I find it invaluable when working with conveyor systems and confusing the maintenance department, which makes me more dollars baby.
This is the first time I am working with Simatic Manager Step7 as I started my siemens journey with TIA which is pretty easy and do a lot of stuff...
149
When you download a DB, the values get overwritten by what is in the "actual" column in offline DB. Does this happen at the start of the PLC...
146
I have a word in some DB which I want to load to AR1 and use as a pointer. In order to do this I need to write L DBxy.DBW xy SLD 3 LAR1 I...
543
Hi, I received a Step7 Backup from my client and tried opening this backup but it won't open as there seems to be files missing from the backup...
3,022
Hi! i'm just wondering did there is any chance to change Set Time(TV) on Siemens plc timer without step 7 using c# or python if timer not set in...
1,258
