Siemens S7 Teleservice
BNA
Sep 2003
Give
117
Hi'
I am having some problems connecting to my Plc by siemens teleservice.
At the Plc i have a Zyxel omni 56K modem connected to at standart PC adapter, and i would like to connect from my laptop with a nokia 6310i.
I can see that there is connection to the PC adapter (the green lamps are flashing) but nothing happens.
Is the GSM phone my problem or what ????
Regards
BNA
Hi there,
For the teleservice you should use a TS-adapter in stead of the PC-adapter.
See info of Siemens.
Various components are required depending on the TeleService function.
For remote maintenance:
TeleService engineering software
1 modem each on the PG/PC and plant sides, Hayes-compatible
TS adapter, on plant side between modem and controller
Modem cable for connection between PG/PC and modem
Modem cable for connection between TS adapter and modem
Optional zero modem cable for direct connection and parameterization of the TS adapter
Optionally required plug (e.g. 9-pin/25-pin)
For PG-PLC remote coupling, in addition to the components for remote maintenance:
PRODAVE MPI V5.0 or later for PG/PC;
Toolbox for process data traffic between SIMATIC S7/C7 for automatic handling of data transfer
Function block "PG_DIAL" (included in delivery) for the controller
For PLC-PLC remote coupling, in addition to the components for remote maintenance:
TS adapter for the second controller
Function block "AS_DIAL" (included in delivery) for the controllers
For sending SMS:
1 GSM radio modem at the plant end, Hayes-compatible
Thank you for your reply.
I must say a very good explanation.
Just to correct my errors in the first question, i have the Teleservice software and the TS adaptor. (I don't know why i wrote PC adapter.)
So what i can see from your reply, my problem is the connection from my pc to the pc modem, i think the modem in my cellphone is the bug ! or what.
Regards
BNA
Hej!
Have the manual but it's 430 kb big so I can't send it here(send e-mail address then I can send the manual).
Have you programmed the TS unit ?
You have to give bus profile, password ,speed, modem type etc.
Some modems need a initialization string eg. us robotics needs standard is &F have to be changed to &F1.
Have used TS with modem and no problem.
First if you are beside the PLC connect the cable to the TS and to the PLC, then try to get the communication to work (direct comm settings in TS).
Excuse my ignorance. I've only worked on Mitsubishi Q-series PLC's, now I'm working on S7 for first time with no training. I'm trying to set up...
1,217
Hi Guys, Got abit of a problem trying to get a Siemens TS Adapter II working inhouse. Got the TS Adapter connected to the phone line and the MPI...
1,974
Anyone here have experience with Siemens S7 Teleservice? I'm in a bind, and need to download a hardward config to a remote PLC, but I can't create...
2,815
Hi people! I want to use Teleservice Siemens software v5.2 for the first time and I don't know exactly how it works. I just want to make some...
2,822
21
