Siemens S7 uploading no comments ??
Dartagnan
Dec 2006
qatar
Hi guys,
I have a kinda small problem. I would like to upload a program from PLC to PC. Everything works fine, except; comments and symbols appear not being transferred. How is this possible?
Could someone offer a solution to make this work?
Thanks in advance,
Team D'Artagnan :nodi:
Because they aren't in the PLC - unless you have saved the symbol table on the MMC . Even then you would lose the DB comments
The idea is that the PROJECT is archived to the MMC- not just the symbol table. Then he will have the DB comments and all.
A quick check- go to acessible nodes> then to the CPU address and see if there is a zip file or folder there.
comments
hello,
if you have an older version of this program you can copy the blocks from the plc in this project. Then you have the "old" comments and symbols. then you must check if networks are moved and if you find operands without symbol.
As I know, NO PLC can save comments and symbol tables within the PLC`s memory; just program code. Maybe there is some of PLC can do this, but I never meet one.
Regards from Kuwait!
save
hello misamark,
e.g. in the GE Fanuc RX3i its possible to save all data. comments, symbol table, additional files (*.doc, *.xls...)
Thanks SPS-Concept!
I did not know that; I have never seen this PLC; seems V good! But, memory inside all PLC is MORE THAN ENOUGH to store all this data; I`m sure; but this seems to be some kind of protection of authors e.g. OEM ? Seems like that?
Regards
Hi everyone, I want to upload the program from my CPU317TF-2 DP to my PC via connecting to CP 343-1 Advanced since it has LAN ports and the CPU...
182
Hello there, currently im working on a s7-200 to s7-1200 migration. Thing is that s7-200 has a TD-200 which contains all of the alarms and i dont...
667
I need some clarification about uploading the HMI file from a Siemens MP277 to edit it in WinCC. Although the machine manufacturer is no longer in...
1,361
I'm using a 3rd party USB to MPI adapter cable. I can see 157 blocks of various types listed under Accessible Nodes in Simatic Manager. The Upload...
28
8,227
Hi all, I'm hardly a Siemens expert, and am struggling with a conversion I'm working on right now. A system was purchased at auction, and I'm...
1,866
