Siemens S7200 - declaring value for set point
raguilas
Dec 2015
Sinaloa
48
Hi everyone I hope someone would be so kind to help me with this issue, I have trouble finding the way to declare a value which I want to be my temperature set point.
So I have an S7200(CPU224XP) and a Panel Siemens Touch "tp177b pn/dp 6"cstn".
and I also have a temperature sensor from which I get the temperature value and this value is located at the VD100 variable.
http://i.imgur.com/x7ntwNW.jpg (VD100)
So I want to create a comparator where" if VD100>"X Value(35°C eg.)"then turn off the resistance(heater)
http://i.imgur.com/HOsYoJ6.jpg (close up to resistance and sensor)
http://i.imgur.com/rEgQ8xb.jpg
I want this variable "X temperature value" to be modified from the panel
siemens.
Do any of you know how I can declare this value in the PLC so I can set it in wincc flexible and be modified from the panel siemens?
What operator should I use in the PLC?
Thanks in advance, best regards and good vibes. =)
siemens.
more than the comparator I think I need to know what adress I should use to set value. =)
hey guys here first time for me in this awesome forum actually i have S7-200 connected to Winview HMI and HMI project file has lost and broken...
605
Hi everyone Does anybody know if it's possible to connect a termopar to an analog input directly? being more specific Siemens S7-200 analog input...
1,690
Hello everyone, I am quite new both in this forum and in the PLC area. I am happy I found this great forum and hope one day I can help with my...
2,244
I am trying to Configure Siemens S7200 (cpu222) with Vijeo citect scada on PPI cable but the problem i face in vijeo citect is that i am not able...
4,312
Hi Can anyaone please help..? I need to bild a line following robot it will be steered and driven by pneumatics, I need to be sent into a...
2,449
