Siemens s7200 + SEW motor
DinoPastorcic
Nov 2013
China
Hello everyone,
I am quite new both in this forum and in the PLC area.
I am happy I found this great forum and hope one day I can help with my knowledge, for now, Ill just try ro learn as much as I can from you guys :) .
Well, here is my problem:
the system is composed from an infeed conveyer, weighing system and an outfeed conveyer (see attachment).
The PLC must ensure that there is only one piece of good being on the weighing system simultaneously, therefore ensuring the correct weighing of the goods.
The presence of good will be controlled by photoelectric sensors EMRON (E3JK relay output).
The PLC must control an SEW motor of the infeed conveyer to ensure the correct flow of good and receive input from the EMRON sensors.
The PLCs I am thinking are the Siemens LOGO!
or Siemens s7200 with CPU221.
I will be grateful for every answer, and hope to contribute to the forum in the future!
Thank you all!
Dino
if there if very little control with few input logo is OK, but if you opt for 200 i would reconsider using 1200 instead. 1200 is the successor of 200 plus it natively support profinet/ethernet.
EDIT:
when you detect presence on the weighing stop infeed, weight, start it, and when presence is on outfeed detected start infeed. repeat.
i don't know how deeper you would like to go, but you could take a look on literature that is in top line of this page (Learn PLC, and there is also a PLC simulator). also there are pages theplcguy.com and mrplcguy.com đź“š
hey guys here first time for me in this awesome forum actually i have S7-200 connected to Winview HMI and HMI project file has lost and broken...
605
Hi everyone I hope someone would be so kind to help me with this issue, I have trouble finding the way to declare a value which I want to be my...
1,290
Hi everyone Does anybody know if it's possible to connect a termopar to an analog input directly? being more specific Siemens S7-200 analog input...
1,690
I am trying to Configure Siemens S7200 (cpu222) with Vijeo citect scada on PPI cable but the problem i face in vijeo citect is that i am not able...
4,312
Hi Can anyaone please help..? I need to bild a line following robot it will be steered and driven by pneumatics, I need to be sent into a...
2,449
