Siemens S7200 Pid ine follow control
charl
Apr 2011
Pretoria
Hi
Can anyaone please help..?
I need to bild a line following robot it will be steered and driven by pneumatics,
I need to be sent into a direction or get examples of a Pid controlled program.
Any help will do.
I dont have much experience i am still a student.
Thank You
PID is a type of regulation which has a Proportional, Integral and Derivative conponent. To begin with a regulator sysnthesis, first you must have an object model. Then you begin with analog PID (Laplace) model, and transform it into a digital (Z) form, using sampling. You can have a digitial model either in positoning or speed form. Problem with PID is how to set constants, there are some ways to do it (Ziegler-Nichols, Takahashi...) or you can use autotuning methods with relay block included.
Instead of a PID, you can use one of non-conventional digital regulators (algorhytms) like Dahlin, Dead-band, Kalman etc.).
Using these keyword in my text, you will find a lot of documentation about PID.
siemens s7200
Thank You for the help so far!
It is the siemens cyberjunkyard project...we are a group and have a project manager who is a robotics expert but we must all come up with ideas...
Thank You
Hi, Peter!
Modelling of pneumatic system is simillar to modelling other mechanical, fluid or electric system. Each system can be more or less aprroximate mathmaticaly described - linear, non linear, partial differnetial quations etc...you know it.
Hello to all, I need its aid. I need to implement a control of pH for acid water neutralization and will use a PLC Siemens S7200, the problem is...
7,328
hey guys here first time for me in this awesome forum actually i have S7-200 connected to Winview HMI and HMI project file has lost and broken...
601
Hi everyone I hope someone would be so kind to help me with this issue, I have trouble finding the way to declare a value which I want to be my...
1,289
Hi everyone Does anybody know if it's possible to connect a termopar to an analog input directly? being more specific Siemens S7-200 analog input...
1,685
Hello everyone, I am quite new both in this forum and in the PLC area. I am happy I found this great forum and hope one day I can help with my...
2,239
