[SIEMENS] SIMATIC S7-300 FB41 PID bloc issue.
intertarik
Jun 2015
agadir
hello,
I'm new in automatics, and i'm working on a speed control project for a hydraulic turbine.
i'm using FB41 pid bloc, but the LMN give me 0 to 100 input.
the SP is 1000 RPM and the PV is calculated from an inductif sensor.
how can i get bipolar LMN -100% ... +100%
if the speed >1000 rpm, then LMN give négative value to reduce the speed.
and if speed < 1000 rpm, the LMN give ^positive value to increase the speed.
thx a lot
Hey,
Try this:
Set the follwing parameters on the FB41 pins or inside the instance DB:
LMN_HLM: 100.0
LMN_LLM= -100.0
Kind regards,
C
thanks a lot that's exactly what i need
one more question...
I have this little network:
and i want to execute it one time
exemple:
when md10<950 E0.0=1
when md10>950 E0.0 = 0
and even if md10<950 again, E0.0 = 0
i hope you understand.
exemple:
You describe a very simple problem here.
Set an M-bit to remember that the MD10 > 9.5e2 and use that M in your logic.
AND! to manipulate an input (E0.0) like this is normally considered bad practice.
Kalle
Hi to all, Our company does not usually use Siemens PLCs, but have a press with one in it. We are trying to change the IP address in our Simatic...
1,070
Hello all, Newbie in Siemens, I want to ask if there will be any issue when I download the instance datablock of a certain Function block? Also...
4,417
Hi guys, Tomorrow I'm heading down to take a look at an existing SCADA system that has failed, and I was wondering if anyone had some suggestions...
18
12,826
Hi Guys, I am facing a problem with my Siemens Simatic S7-300,CPU 315-2 DP( 6ES7315-2AF03-0AB0 ).That is in the morning i dont know why but it...
3,354
Could anyone please tell me why i am getting 'illegal command' message whenever i tried to download to the PLC and i can not download to the PLC...
1,297
