Siemens Simatic S7-300 Question
arocon
Oct 2006
Dubai
171
Could anyone please tell me why i am getting 'illegal command' message whenever i tried to download to the PLC and i can not download to the PLC. I use Siemens Simatic S7 CPU 319F-3 PN/DP. I am trying to use this function for taking data to the data acquistion system.
If anybody please help me as soon as as possible it will be great help.
arocon
You have transfers to QW3000 etc in your FC - have you/can you set the process image to cover these addresses ?
If not, then use PQW3000/PIW3000 etc.
Hi to all, Our company does not usually use Siemens PLCs, but have a press with one in it. We are trying to change the IP address in our Simatic...
1,074
Hello all, Newbie in Siemens, I want to ask if there will be any issue when I download the instance datablock of a certain Function block? Also...
4,425
hello, I'm new in automatics, and i'm working on a speed control project for a hydraulic turbine. i'm using FB41 pid bloc, but the LMN give me 0...
2,270
Hi guys, Tomorrow I'm heading down to take a look at an existing SCADA system that has failed, and I was wondering if anyone had some suggestions...
18
12,848
Hi Guys, I am facing a problem with my Siemens Simatic S7-300,CPU 315-2 DP( 6ES7315-2AF03-0AB0 ).That is in the morning i dont know why but it...
3,362
