siemens simatic s7 usb adapter: broken?
horatio
Oct 2006
in a box
greetz,
i have a siemens simatic s7 pc adapter usb (serial 6es7 972-0cb20-0xa0) and plan on connecting it to the siemens PLCs in a goss web press to pull diagnostics. however, after having installed the drivers for the device, i see no indication that it is getting power.
the manual for the device says that upon connecting it to the USB port of a function windows machine that the USB and Power lights should light up green. this is not happening for me. could this be because i have not installed the right driver?
i am rather familiar with windows and installing new hardware so this is confusing to me.
any suggestions appreciated.
cheers
Good Evening , It has been several years since I used Siemens Software . I’m looking to purchase the software for a Siemens Simatic S7...
503
I'm just trying to figure out the right method of adding a DO card to an existing rack. It's not the *next* open slot, but I have to move the AO...
557
Hi to all, Our company does not usually use Siemens PLCs, but have a press with one in it. We are trying to change the IP address in our Simatic...
1,071
Hi. I have 2 files where I would like to see the ladder logic differences (similar to the Rockwell compare function). I am using TISoft Siemens...
1,268
Hi all, First time posting here. I have a Siemens Simatic S7-1200 controller that I intend to use for a small project at home. I also have a...
2,032
