Siemens simatic s7
dvdoornik
Nov 2003
Vrouwenpolder
Hello guys,
during a (very short) project on our faculty of my highschool I was asked for a project on the s7 (and other plc's).
The question of a installation company was: is it feasible to read out the status (in and outputs) from the plc. The Siemens S7 is common used, but others are used too. I was wondering if I could find a manual how to read the status (for emaxple in visual basic or c++). I am using a TS module, so my s7 is connected to the pc through the COM port (RS-232 serial data).
If anyone can help me out I would be very grateful.
Kind regards,
Dave :oops:
not step7
forgotten, I don't want to use step 7 or some other software, because I only want to read the plc's status. Step 7 is much too expensive...... :( So I need to write the software myself.
Dave
Dave,
if you want to read the status of the I/O (and internal bits, timers, counters, etc.) you need to know the MPI protocol. Since you don't want to buy the STEP 7 software, it is impossible to implement another communication standard on teh S7 PLC.
The MPI protocol is a very well guarded secret with Siemens. It's even better guarded than fort Knox :p ! Yhe only thing commonly known about MPI is that it is using RS485.
The only other solution is to buy a DDE or OPC driver to get access to the internals. There are different possibilities:
  • Applicom has a FastDDE driver and a SuitLink driver (only for WonderWare ???).
  • ATS also has a FastDDE driver. You can download a demo.
  • Merz has an OPC driver. You can also download a demo and the manual.
These are the ones I know about. By searching the net for MPI and OPC or DDE you might find more.
Kind regards,
someone
Hello thanx for your request,
i knew it was guarded, but isn't there anyone who knows the protocol? I guess there are a lot of people who wants to know it... ;)
Dave
Good Evening , It has been several years since I used Siemens Software . I’m looking to purchase the software for a Siemens Simatic S7...
515
I'm just trying to figure out the right method of adding a DO card to an existing rack. It's not the *next* open slot, but I have to move the AO...
565
Hi to all, Our company does not usually use Siemens PLCs, but have a press with one in it. We are trying to change the IP address in our Simatic...
1,082
Hi. I have 2 files where I would like to see the ladder logic differences (similar to the Rockwell compare function). I am using TISoft Siemens...
1,283
Hi all, First time posting here. I have a Siemens Simatic S7-1200 controller that I intend to use for a small project at home. I also have a...
2,062
