Siemens Simatic Step 7 (IL,FBD,LAD)
ErikSBE
Feb 2005
Hello,
Can anyone tell me if it difficult learing programmming a Siemens S7 PLC ?
I am fammiliar with the IEC61131-3. (programming e.g. Beckhoff Twincat).
Siemens seems to be a little bit more complex ?
greating
Erik
Siemens isn't more difficult then others, it's just like other new software, it take awile to get it into your fingers.
Siemens supports IEC61131-3 but Siemens shouldn't been Siemens if they haven't put some odd things into it.
Rudi
You may be in luck. The older Beckhoff system, SCOM5, was more or less a direct clone of Step5. Given that Beckhoff is a German company and Siemens totally dominates the German market, it is probably not unreasonable to assume that they will have retained a certain similarity to Step7.
As far as I'm aware, only SCL is 100% IEC 61131-3 conform, and it's not a part of the basic package.
Hello Fritz,
Thanks for the quick reply !
Do you have any references to online training for Siemens S7?
grt
ErikSBE
I'm just trying to figure out the right method of adding a DO card to an existing rack. It's not the *next* open slot, but I have to move the AO...
557
Hi , I am working on Siemens CPU 315-2DP(6es7315-2af03-0ab0) while working online i try to modify bool value memory address M33.3,M34.0 but it is...
2,337
Hey All, We recently acquired a new used machine off the surplus market. there are two sections to the machine, each with its own PLC/HMI and...
46
11,856
Hello, Today I install Siemens PLC software SIMATIC Step7 v5.4. after installed, I start SIMATIC manager. it pop up "Run-time error 35600, index...
10,185
i was a problem in plc programming pc it windows was currepted it licence kay taken in pen drive and formate the whole programe after installation...
7,562
