recycled_mind
OP
I will be making a technical specifications wherein I will specify SIEMENS so that no other brands will be qualified to bid.Why do you want to know this ?
The only reason I can see that someone would specify a system, is if the customers' engineers, technicians, or electricians are already well versed with that vendors software & products.
I don't think any other PLC has a RUN STOP RES switch along with a memory card slot of the front of the CPU.I will be making a technical specifications wherein I will specify SIEMENS so that no other brands will be qualified to bid.
Yes, Jesper. That is why I need the unique characteristics of Siemens since it is not allowed to specify a certain brand.I kinda suspected it had something to do with that.
If this is for a public utility, such as water supplies, WWT, tunnel lighting or similar, then in the EU it would be illegal to specify a certain brand.
I have had this discussion before with another European engineer that writes specifications. To specify specifically a S7, just specify there must be a RUN STOP RES switch on the CPU.
Actually, I am comparing how much tech support is required of us that should be provided by the PLC company.I realize Peter is doing custom stuff and comparing it to how much work he has to do with what it takes to do AB or another platform.
Past that, here is why Siemens is my preferred programming package: I can knock out a program faster with S7 than with AB or GE. Once you get a few projects under your belt and have code to pull from, the program just writes itself. I could expand on this, and will if asked, but for this post I will leave it at that.
