Siemens Starter Software
aandjsam
Sep 2016
lincolnshire
30
Hi all,
I'm currently trying to configure a number of G120C drives and am using Startdrive in TIA portal, however I've had a recommendation from someone to use Siemens Starter as a standalone software. I cannot for the life of me find the download anywhere online though. Can anyone direct me to the download please?
Thanks,
Sam
I like Starter too, because I’ve used it for years.
I think the only thing Startdrive lacks now is the scripting Starter has.
I've managed to get the project finished, However I've got one problem I'd like to overcome.
When first powered on I'd like the operator to have to press a reset push button before the drive can be enabled.
Is there a bit in the drive that is similar to a first scan bit like you'd have in an S7 PLC? if so, what bit is it please?
Yes. You can make one,
A reset pb wired to where?
Wired to DI 2, when STO is activated, it sets a RSR block, which turns the reset indicator on and also inhibits the drive from starting. To reset the RSR block, the user must press the reset push button.
I need to make a parameter change on a drive using STARTER. I am using this for the first time so I want to make sure I am doing this right. I can...
1,599
We just started up a new production line with all Siemens controls. This is my first experience with Siemens. I am not impressed. So I'm trying to...
2,215
I need to change a parameter to a drive in Starter. I know just enough about Starter to get me in trouble. Is this correct procedure.... When...
1,589
Hi, I am interested in buying a Siemens starter kit. I came across this site, realpars.com Does anyone know if this is a reputable company?? Any...
1,187
Hi All, I have a Simens CU320 drive controller that I wish to connect to via the X127 ethernet port. The unit communicates with the CPU vua...
4,115
