Siemens Step 7 - Monitoring Indexed Program
PaperMan
Jul 2007
Weeton
Hi All,
I have written an indexed program that controls 8 identical machines. Each machine has an identical DB which contains a map of all its inputs, outputs and control flags (inputs and outputs are moved in and out of the DB at the start and end of the scan). Each DB is passed in turn (in a for-next loop) into the main program FB and it all works very well.
When I wrote the program it was on one machine - which I could monitor fine (when I got it going I simply increased the For - Next loop to include all the other machines)
My question is... now that I have 8 machines running through all the same FB's and FC's one after another on the same scan – all using different data, is it possible to monitor just one of them on its own? If I monitor an FC at the moment it will try and show eight different situations at the same time (if that makes sense)
Many thanks in advance
Is there a way to monitor the error indicators of the PLC from Step 7 V5.5 SP3?
1,704
Good Morning, Hoping someone with some Siemens experience can give me a hand with this one. Customer has a S7-200 cpu, which has a 6GK7...
253
I'm just trying to figure out the right method of adding a DO card to an existing rack. It's not the *next* open slot, but I have to move the AO...
557
Hi Siemens Experts, I am hoping someone can shed some light on my issue. I have uploaded the code from a S7-300 (317-2PN/DP) using Step 7...
690
Hello, We monitor the temperature of a pipe via a 4-20mA temperature transducer. This goes into DB135(Read Analog Inputs). The issue I have is the...
630
