Siemens Step5 on Windows7
Manglemender
Jul 2007
Lancashire
1,295
Hello Forum members,
I'm curious... has anyone tried to run Siemens Step5 V7.23 on Windows7 yet?
I'm getting a new laptop and it will come with Windows7. I have a solution with VMware but I was wodering if it would run under Windows7.
Nick
Yes it runs in a tiny dos window that you cannot I repeat cannot resize. ie 640x480 resolution. Properties run in xp compatibility. Couldn't get the com246 add on working properly. But to be honest the resolution issue is a pain and it is better run on an XP machine or in VM.
solution that we are using: install XP and 7 on the same pc and boot on the right version depending what you have to do
Thanks for the answers,
I'm going to go with the VMware - XP solution for now and see how it goes. I'm also going to try VMWare - DOS to see if it overcomes the screen size issue.
Nick
A word of warning to anyone else wanting to run S5 in VMWare. Don't select more than 1 processor for the virtual machine or you end up with a blue screen when you go online.
Nick
Hello Everyone! I just became a member of this great site. I have a PLC program from an S5-100U PLC, and now I want to make a PDF report of all...
1,586
Hi guys. I'm looking for a simple method of scaling an analogue output on a Siemens 150u. On the 115u in comparison, I would simply use FB251...
20
5,924
Hi Guys, Could anyone please help me understand how this instruction in step5 works: ----(#)---- it has the address F1.5 in particular for the...
1,731
Dear PLC Experts, I am trying restore program in Siemens S5 115U CPU 945.I have backup of program unable to open with STEP 5 V7.23. I tried with...
11,591
I have a New Siemens PG with a MPI/DP 9 pin port on the back of the PG itself. I am trying to connect to a Siemens Simatic 505 with a 525 CPU 9...
9,583
