Siemens STEP5 - protection problem
sterowniczy
Jan 2006
Kolora
Hello!
I have a problem with error AS Function disabled. One of solution is to reset the system bit RS 120.0. I cannot do that because my PLC has program in EPROM.
How can I check if RS 120.0 is setted?
Variable status does not work.
Thanx
Which CPU ?
The 928B manual, for example, (http://support.automation.siemens.com/WW/skm/pdfviewer.asp?HitsPerSite=10&ehbid=html_76%2Fehb%2F19397726%2Ehtm&lang=en&nodeid=19396029&query=928%20system%20manual&page=1&view=new)
shows the following. You can show memory contents from Step 5
Type of my PLC is S5 944B (it operates with OP27)
is it possible to reset this bit via STEP5 (direct acces to PLC memory) without changing the program (adding RU RS120.0)?
Thats the way I read it. If bits 1 and 2 are set then this will disable the PII,PIQ updates, thus RS120.0 is located in EAF0
Hello
I've tried to change value 1 to 0 in the EAF0 address but after correction the value is still the same (1)
what should I do?
Hello Everyone! I just became a member of this great site. I have a PLC program from an S5-100U PLC, and now I want to make a PDF report of all...
1,584
Hi guys. I'm looking for a simple method of scaling an analogue output on a Siemens 150u. On the 115u in comparison, I would simply use FB251...
20
5,918
Hi Guys, Could anyone please help me understand how this instruction in step5 works: ----(#)---- it has the address F1.5 in particular for the...
1,729
Hello Forum members, I'm curious... has anyone tried to run Siemens Step5 V7.23 on Windows7 yet? I'm getting a new laptop and it will come with...
13,129
Dear PLC Experts, I am trying restore program in Siemens S5 115U CPU 945.I have backup of program unable to open with STEP 5 V7.23. I tried with...
11,588
