Siemens Step7 & VIPA PLC
junior
Jan 2006
Seattle
271
Happy Holidays!
I have Siemens Simatic Step 7 v5.5 and I'm wondering if you can use it to program a VIPA PLC? or do you have to use the WinPLC7 softwware?
Searching around the internet, it seems like the two software packages are interchangeable, but I haven't been able to get a definite answer.
TIA
Jr.
Happy Holidays!
TIA
Jr.
You can use the STEP 7 for programming of Vipa.
Just be aware that some models can not be programmed with STEP 7, and that you choose the right Siemens CPU for the VIPA CPU in the Step 7 hardware configuration.
STEP 7 is perfect to program VIPA PLCs. The hardware configuration of the VIPA CPU takes place at the Siemens hardware configurator. Each PLC manual (www.vipausa.com) from the download area, shows you the associated Siemens PLC to choose in the deployment section, generally chapter 4.
This is the first time I am working with Simatic Manager Step7 as I started my siemens journey with TIA which is pretty easy and do a lot of stuff...
190
When you download a DB, the values get overwritten by what is in the "actual" column in offline DB. Does this happen at the start of the PLC...
167
I have a word in some DB which I want to load to AR1 and use as a pointer. In order to do this I need to write L DBxy.DBW xy SLD 3 LAR1 I...
564
Hi, I received a Step7 Backup from my client and tried opening this backup but it won't open as there seems to be files missing from the backup...
3,060
Hi! i'm just wondering did there is any chance to change Set Time(TV) on Siemens plc timer without step 7 using c# or python if timer not set in...
1,272
