Siemens Switch Disassembly
Eric Nelson
Apr 2002
Randolph, NJ
4,346
I just received a piece of equipment with a Siemens 3LD2254-0TK53 mains switch (see attached picture). I can't access the incoming power terminals without removing the switch first, but I don't know how the contact block separates from the switch.
Is there a release tab, or do I push and twist, or something else? I'm sure it's easy, if I only knew the trick :ROFLMAO:
I've dug through the datasheets and manuals online, but don't see any disassembly instructions. Any ideas?
-Eric
Um, hit it harder? :)
The shields like this that I've seen and used just popped off with a little twist and pull. Sometimes the wires liked to help if they were flexed too tightly. Are those blue shields really on there that tight?
-rpoet
I don't recall seeing that red locking lever on mine, but I'll check when I'm at the machine again. Looks promising though. Thanks for the picture, osmanmom (y)
-Eric
Hi all, First, thank you for reading the thread. So I had a task as the following: An up-counter must be programmed as part of a batch-counting...
300
Hi everybody. Today I need to program tow DI s for the Siemens CU250S-2 DP drive to act to stop the drive in the + and - directions when they hit...
3,379
Have a long rung from PC to PLCs. Bought a X101-1 switch to convert Ethernet (Profinet) to fiber. (X106-1 at PLCs end). The only configuration is...
1,926
Hello, I'm not a Siemens person so I'm a little confused what can be missing in siemens ethernet configuration. I have S7-300 with 343 module and...
3,526
I have a Siemens S5 CPU 928B with a main rack and 3 remote racks. The plant is stopping without any alarms or fault indication. You can go to the...
18
3,849
