allennzcontrols
Using siemens block to control pressure level. The PV is pressure in Bar and the output is vsd fan speed in %. What I require is when the PV is high the fan speed to increase to bring down the pressure. However it's doing the opposite eg increase in pressure = decrease in fan speed. Easy way to solve this is to set a negative gain but the block does not accept that
Help!!!
Help!!!
