Siemens TIA Portal v13 tp700 comfort Screen Saver
Nan
Jul 2015
louisville
126
Hi all,
I would like to add four pictures as screensaver, the HMI will start the screensaver after 1 min idle, and then change between the four pictures every 10 seconds.
I know 'ActivateScreenByNumber' and job mailbox, but now sure what exactly what should I do step by step. Thanks everyone! I appreciate for your help!
You may want to look at the simulate tag function. It will increment a tag by a value. If you put this in the open event of the screen saver then you could use it to index through a list of the images.
86
Hello, good morning, I have been having two problems with the Tia Portal software. The first is that I have installed it on my computer and...
187
I am currently am in a PLC class and need urgent help on how the ladder logic would be laid out. I understand how to get the traffic lights to...
19
482
Hello, If the date on the license manager of tia Portal has expired, can I still work with it? or is this just to keep the program up to date...
241
Hi everyone I've created an FC that includes the blocks TCON, TDISCON, TSEND and TRCV. This block has to be as generic as possible across...
1,561
