Siemes PCS7 to AB SLC's
cornbread
Feb 2007
madison, indiana
407
Looking for opinions on how best to interface a Siemens PCS7 controller to Allen Bradley PLC's. Micrologix & SLC500's.
I see where they have echo change Ethernet/IP gateway.
I also see that Profibus is another option.
Looking for other oprions and what are the pro's & cons of one versus the other.
As always your help is greatly appreciated.
I really don't know at this time. I would assume it to be small as the AB PLCs are doing all controll now, eventually the plan is to replace the AB's with PCS7.
Have you some plan on stages on replacing control with pcs7? Do you plan to use ab as just io at one point, or do you have possibility of just shutdown for duration of overhaul? If there is possibility of large amount of data to be transferred at one point, i see no reason to use anything other than ethernet based system.
Dear all, I can read (upload) the plc project easily. But when I try to download it almost complete (like 100% downloaded program block also data...
3,986
hi frens, i am new to siemens programming. i have done a project on siemens s7 300 cpu317, i manage to write the logic sequence successfully...
2,373
I have a project where I need to talk to and from a Siemens 7SJ6 relay via profibus. Is it as simple as adding a prosoft card MVI46-PDPMV1?
1,602
Hi I am seeking clarification. If I do a RAM to ROM on a CPU with a MMC (3152PNDP) does this create an exact snapshot of the running software...
1,864
Who can help me to the example program for the integrated Puls Width Modulation function(SFB49) of the Siemens S7 3xxC CPU. I think it is...
4,499
