Signal Surge Protection
Engineer_UA
Oct 2016
California
43
Hi Folks,
Is surge protection recommended for field wiring connected to PLC inputs? For example, I/O originating from field devices located outdoors and routed indoors and connected as inputs to the PLC? The field wiring would be routed in grounded steel conduit, my concern would be for any lightning/transient conditions.
Thanks,
EE
It's an expensive and cumbersome job, but I have done it at highly lightening prone sites.
In the long run, it's less expensive than replacing input modules.
Since you did not specify the type of I/O.
This should cover most field devices.
https://www.eaton.com/us/en-us/products/backup-power-ups-surge-it-power-distribution/surge-protection.facets$4089882017$2598156606.html.
Quote:" In the long run, it's less expensive than replacing input modules"
As long as you aren't concerned about down time, labor or travel expenses.
I am not sure why this is requested, but it was asked. Currently I have one PLC , with one output to a relay, turning on a field equipment (just...
246
Hi, I am working on automating an industrial fabric shrinkage tester to replace its outdated electronics with a PLC. To get the tank's water level...
17
843
Hello, I have a compact Logix plc and I have been task with configuring alarms into our SCADA when an Analog signal stops moving. The analog...
273
Hi I have an old panel builder 32 that I’m replacing for a factory talk me hmi . In the plc for the old panel builder there is a coms bit for the...
85
I'm pretty new to PLC's, so forgive me if I use the wrong terminology and whatnot. We have an issue at work where we have a flow meter that is...
314
