Simatic ET 200S CPU
jillgeorge18
Feb 2016
Cochin
26
Hello to All,May I know the difference between local io and distributed io ?and what's the function of fail safe modules in ET200S?? and If I have a S7 300 CPU and can I use ET200S as a slave device through Profinet??:mad::mad:
The difference between distributed and traditional I/O is it the name, its distributed. You would use distributed I/O when you want more than 1 point where are all the wires are going to.
Traditional I/O has all of the wires going to 1 point, the MCC (main control cabinet). With distributed I/O you would spread this by having additional smaller cabinets with its own I/O.
The function of failsave I/O in a ET200s is to use it in concjuction with a saftey plc. With a safety cpu and saftey IO you can wire E-Stops directly to the remote I/O stations.
Yes you can use a ET200S as a remote I/O station, you could use a IM151-3pn for this. If you want safety in this station you need a HF (high feature) version of this interface module
Hello to All,May I know what are the main advantages of Simatic ET 200S with respect to other S7 CPUs????I tried to get from internet but some...
2,053
Hello. I'm trying to comunicate to Siemens SIMATIC ET 200S IM 151-8 PN F-CPU using CitectNexa 6.1 via Ethernet. I don't know wich Citect driver...
1,720
Hi guys, I think, you know this issue... the last power module at the ET200S rack (sometimes) indicates system fault (SF diode) but everything is...
3,180
Sorry for my mistake... how to delete this thread?
2,544
HI i would like to know how to get a variable that will store the amount of times a program has been executed. The issue is I have 3 DBs for 1 FB...
83
