Simatic PDM HART modem - can't establish communications
danw
Oct 2004
midwest, USA
3,428
Neither a USB nor a serial HART modem can be "seen" by PDM V6.0.
According to the help files, there's supposed to be a tab in the "COM Interface Properties" dialog box called "Connecting Data", but it doesn't appear, so I can't set the COM port. (Serial modem is on COM 1, USB modem is on COM 5)
I do see "general", "Network", "Change Log" and "Import" tabs.
The "Network" tab allows a choice of HART modem, but that's it.
Any ideas on where one establishes the COM port for Hart modems?
Dan
I had similar problem,I used a 250ohm resistor and all worked after, you could always try calling siemens pdm tech support for hours of mind numbing abuse.
Turns out it was a software installation issue.
The Goddess of IT installed the Simatic PDM software, managing the licensing through Siemens' license manager, but she didn't install the Device Descriptor library, because IT people are bureaucrats.
Simatic Manager won't link a COM port to a HART modem if it doesn't see the HART DD library.
When I got the DD library installed, the 'Connections' tab appeared as described in Help and I got through the rest of creating a project, ya-da, ya-da.
Dan
Can anyone tell me what this problem is and how to solve it? The error message is in the attachment. Best regards
3,878
Hallo. I am new to this,I am Using a DR 21 controller with interface module RS232 FOR serial communications with rs 232 cable, I want to...
1,894
HI i would like to know how to get a variable that will store the amount of times a program has been executed. The issue is I have 3 DBs for 1 FB...
91
Dear sir, I am using SIMATIC 300, CPU 315-2DP , (6ES7 315-2AF03-0AB0) VIPA 603-1CC21 A1.0 RAM 32KB, Firmware=V4.0.8 The problem Im using MPI...
174
Hi, I received this SIMATIC S7-300 training kit for maintenance. When I power it up, the PLC doesn't go to RUN mode and the STOP mode led is...
312
