Simatic S5-100 U Comms and Programming
bhedding024
Jan 2004
Great Falls, MT
29
I have a 6ES5 100-8MA01 that came in without the EPROM installed. I followed the procedure to get the program loaded and it goes into RUN mode but the machine does nothing. Not 100% certain it's not a wiring or other control issue but trying to explore all the options short of chucking the thing in the trash and staring over.
For what it's worth the battery was also replaced because it came in dead. Machine had been sitting for some amount of time.
Trying to determine the easiest path to get it connected to a PC. I found a cable online fromthe EU that allegedly connects the PLC programming port to a USB port. However, it would appear the Step5 software only runs on Windows 3.1 or 95. Would something like VMWare work in this scenario? Any other advice?
Thank you!
I have a 6ES5 100-8MA01 that came in without the EPROM installed. I followed the procedure to get the program loaded and it goes into RUN mode but...
975
Hi all, First time posting here. I have a Siemens Simatic S7-1200 controller that I intend to use for a small project at home. I also have a...
2,030
I've got a potential customer who has an existing system with a Siemens S5-100 and and eprom plugged into the cpu. He wants me to convert to...
2,671
HI i would like to know how to get a variable that will store the amount of times a program has been executed. The issue is I have 3 DBs for 1 FB...
83
Dear sir, I am using SIMATIC 300, CPU 315-2DP , (6ES7 315-2AF03-0AB0) VIPA 603-1CC21 A1.0 RAM 32KB, Firmware=V4.0.8 The problem Im using MPI...
170
