simatic s7 trial version question
Apr 2011
Manila, Philippines
295
Good Day,
I installed simatic s7 manager (trial version) and after the trial period of 14 days I decided to re-install the software but after the installation, it prompts an error message of "No license Key found, Program will close".
Is a chance for me to avail the trial version of simatic s7 manager??
Thank you Guys.:geek:
Either reformat your PC or Ask for a further 14 Day trial License.
Dont use illegal pirate software.
Thank you Sir, Good thing the software is genuine. :).
http://support.automation.siemens.com/WW/view/en/24200966
Siemens.FAQ: How can you deactivate the Trial License when the message appears indicating that the Trial License has expired, although the Floating License has been installed?
remove trial keys SITT***.EKB and trial dirs (C:\Windows\*******ttis and C:\Windows\System32\*******ttis)
thank you very much, I was just learning simatic software from my company network and I couldn't open the SIMATIC Manager after 14days as my trial version got expired. So I followed these procedures which I read from here. Once again I am repeating those. First of all I closed all applications. And then,
1. Went to C drive and deleted the folder named <AX NF ZZ>. (you can search it in c drive.
2. Also I searched for files ending with <attis>
3. There was 5 files on my C:\WINDOWS\system32 directory. I deleted all of them and restarted my SIMATIC manager. And it had given me a new trial license valid for another 14 days.
thanks very much guys.
regards
I have a SIMATIC Industrial PC SIMATIC IPC227D with a PC monitor connect over DVI. I am trying to add a second monitor to this but the second...
1,202
Hello everybody, Has anyone ever tried to add two IE General on a Simatic Station? I have a line with 5 PLCs supervised by a Simatic station...
3,103
HI i would like to know how to get a variable that will store the amount of times a program has been executed. The issue is I have 3 DBs for 1 FB...
99
Dear sir, I am using SIMATIC 300, CPU 315-2DP , (6ES7 315-2AF03-0AB0) VIPA 603-1CC21 A1.0 RAM 32KB, Firmware=V4.0.8 The problem Im using MPI...
177
Hi, I received this SIMATIC S7-300 training kit for maintenance. When I power it up, the PLC doesn't go to RUN mode and the STOP mode led is...
313
