Simatic step 7
ebolbol
Apr 2011
CA
175
First dumb question: what is Simatic Step 7?
Second dumb question: can it open a project created in ProTools v 6.0 in runtime or build environment?
Thanks in advance :geek:
:unsure: Ed
:unsure: Ed
Simatic Step 7 = Programming software for the S7 series Siemens PLC's 300,400)
No it cannot open Pro-tool projects.
You'll need Pro-tool or WinCC Flex
Try to stick to Protool - Wincc does not convert program over fully due to Password system changes.
ProTools v 6.0
I have a demo version of ProTools v 6.0
Is there a pain free way of obtaining a full version?
I will pay for it if I have to. I don't even want the latest, V.6 will do just fine.
Thx
Ed
Protool
Protool can be integrated or stand-alone. When Integrated, then you can you open your Protool project in Simatic Manager. Simatic Manager just manages your PLC program blocks in any language (depending on what's installed), PLC hardware, drives, HMI's, all in one project. It is not the software where you program with, just a manager for starting up the right software. When installing Simatic, LAD/STL/FBD is installed, when you open a block written in LAD for example, then LAD/STL/FBD will start-up and open your programblock. If Protool is installed in an integrated way, then you can integrate your HMI's in you Simatic Project and you can start it from Simatic Manager.
Regards,
Combo
Protool
Very helpful. Thank you Combo
Regards,
Combo
I'm just trying to figure out the right method of adding a DO card to an existing rack. It's not the *next* open slot, but I have to move the AO...
561
Hello, I have posed a similar question before, but the DB then provided me with pre-allocated "spares". In this instance I need to declare a...
4,141
Hello, Im looking for a VMware with SIMATIC Step 5. I would be very grateful if someone could help me with this...
1,168
Hi , I am working on Siemens CPU 315-2DP(6es7315-2af03-0ab0) while working online i try to modify bool value memory address M33.3,M34.0 but it is...
2,342
Hey All, We recently acquired a new used machine off the surplus market. there are two sections to the machine, each with its own PLC/HMI and...
46
11,943
