Simatic TP 170A HMI (generate screen through S7-300 PLC)
jaichains
Jul 2005
Rotherham
46
Hi all
I am using Simatic TP 170A HMI using ProTool 6.0 SP2 with a S7-300 PLC. I need to know how can i change screens on the HMI from the PLC i.e the HMI should read values from a register in PLC and change screens. Example: If the register in PLC says 5, screen 5 in HMI should be generated.
Pls.all help me in this one, if possible. Thank you very much.
generated??
You can use PLC job 51 to change screens or if the TP170A is a windoze CE panel you can do it this way.....
Create a integer tag and go to "Functions" for that tag, select "Screens" and "Select Screen Variable". Under the "Options" tab set the "Read Cont" check box ON. The screens will change when you change the value in the Int Tag. It is easy to try from a VAT in S7.
Thanks to RRobbins for that little nugget.
Paul
HELLO, A friend of mine bought a TP170A HMI, and was trying to connect it to a Siemens 505 and can't get it to talk, now everything that I have...
4,584
Hello All I need to get the Backup of TP170A for this I tried PROTOOL and PROSAVE and configured communication parameters via COM1 Gives Error...
3,058
Could not established the connection with TP170A The software I am using are Windows XP SP2, Simatic ProTool ver. 6.0 SP2 and Simatic Prosave ver...
4,509
I have a Siemens S7-200 PLC and Simatic Panel TP 170A but I can't get them to "work" together. I can program the PLC with STEP 7-Mirco and the...
7,802
HI i would like to know how to get a variable that will store the amount of times a program has been executed. The issue is I have 3 DBs for 1 FB...
83
