Simoreg K 6RA24 dc drive
electronics
May 2009
mandini
We have a winder(paper machine) application with a Siemens 6RA24 drive. On startup the drive is coming up with fault F04. We have eliminated the fault by decreasing the startup tension on the system from 7 to 3. Once the drive is able to crawl, we input the default tension(7) and therafter run the machine without any faults. We have basically found a quick-fix to eliminate the fault on startup and have not found the root cause. I have looked at previous threads by sammy_s and have played around with P086, P087 & P089 with any success.
Please assist with further suggestions.
Mr Electronics
Looks like your initial motorstart current may be too high.I would put an amp clamp on the offending phase(using the diagnostics) and measure the startup current.I had a similar problem with an AB unit and found that it was a setting for startup overcurrent,but your app is different.Also we went to a gear reducer to reduce startup tourque.
hi i need help to finish my start up for simoreg drive 6ra24 1200 amp we use it for 450 kw motor for cement factory. i face many problems 1-no one...
5,754
We are in need of Simoreg 6RA24 Spare parts but nobody quoted. Anyone knows what is the status of this product?
3,849
Hi Can someone please tell me where I can find information about the heat developent / dissipation of a Simoreg DC Master? 📚 The information...
941
Hello people This is my very first post in plctalk, so im sorry if my question is out of place. We're using a simoreg dc drive and currently is...
1,528
Dears kindly need support to replace old SimoReg DC master Siemens Drive and upgrade to sinamics 6RA8081-6DV62-0AA0 series communication is...
2,471
