simotion d425 scan time problem
dardary
Oct 2006
il
hi
i have simotion d425 with smart module line and singel motor module and duble motor module and 3 1fk7 motor
all siemens.
ok
i have problom with scan time of dp profibus clock and d425 clock
some one have any idea what the parmeter for this?
DP1 and integrated profibus
DP1 and the integrated profibus have to have the same setup; so DP1 needs to be setup as 12MB with Constant Bus Cycle Time Activated and a constant DP Cycle time of 1ms. The DP2/MPI port can be setup however you need it. Do not attach an HMI to the DP1 port it will not be happy.
Hi, Has anyone connected a D425 drive to Kepware before? I've read you need to enable an OPC through scout. We have tried this, but cannot get...
1,912
Hi all, I'm trying to bring info from a D425 into TOP Server (same as KepServer). All of the tags inside of the D425 are named variables...
2,265
Help me to read an analog value from Cpu 315 for simtion controller to control the speed of one of the servo motor over MPI. If it is not possible...
3,083
Hello everybody, I'm currently working on a project where I need to implement an IoT platform based on Microsoft Azure Cloud. Communication is...
50
Can we use a Simotion D455 ethernet port x127 as a gate, to access S7-1500 plc Tia Portal program ? In the Simatic manager, we used Netpro to do...
93
