SIMOTION D425 to TOP/KepServer
dripdry
May 2016
Ohio
23
Hi all,
I'm trying to bring info from a D425 into TOP Server (same as KepServer). All of the tags inside of the D425 are named variables ("Knife_Offset") and not the traditional data block stuff. I'm entirely new to Siemens stuff, can anyone help a guy out? 🤞🏻
Hi all,
The named variables most likely are Global Variables.
Browse to your D425 folder and check under "Global_Var" folder.
It may be all you need to do, I haven't done TOP server with Simotion.
Usually, when setting up and HMI (Siemens, MP, Comfort) you browse under the connection to the "D425" controller in your project and then to the folder that contains your variables.
Hi, Has anyone connected a D425 drive to Kepware before? I've read you need to enable an OPC through scout. We have tried this, but cannot get...
1,914
Help me to read an analog value from Cpu 315 for simtion controller to control the speed of one of the servo motor over MPI. If it is not possible...
3,084
hi i have simotion d425 with smart module line and singel motor module and duble motor module and 3 1fk7 motor all siemens. ok i have problom...
3,815
Hello everybody, I'm currently working on a project where I need to implement an IoT platform based on Microsoft Azure Cloud. Communication is...
51
Can we use a Simotion D455 ethernet port x127 as a gate, to access S7-1500 plc Tia Portal program ? In the Simatic manager, we used Netpro to do...
93
