Simple aplication
Foty
Oct 2002
30
I want to automate my fathers garden. Turn on/off the water and I want to be able to consider outside condition in order to water it when it necessary. My question is what should I use as controlling device? I was thinking of using the S7-200 or a Logo.
Seems like overkill. But I didn't say don't do it!!!
There are many watering controls that can be readily used . And considerably cheaper than a plc or smart relay plus the valves and all.
Do a search on rain sensors ,some can be integrated to these watering controls . here's one link rain sensor
Drewcrew6
Garden automation
Another thing to consider is a couple of plastic rainbarrels with level switches to allow makeup water from the potable supply if your water level in the catch barrels gets to low . A PICO EASY LOGO AutoDirect or any of the "almost a PLC not just a progammable brick" might be cost effective if you can repair sensors and or get some very cheaply. I am going do the same type project but include lighting the chicken house, heating, watering and other things as I can think of them and then finance them. Pops has always been an on his feet and busy guy but a triple bypass and other things can slow things way down. So this way he can still take manual control when HE WANTS to and let the equipment handle it otherwise.
Hello, I´m having a problem trying to program in Ladder. An output should be trigged by two possible contacts. Take a look on the printscreen...
165
Hello again..trying something on an existing poorly written program and just wanted to double check something system is an A-B MicroLogix 1200 In...
197
Hi all, Writng a FB in ST on Beckhoff TC for a pulser which turns on and off on a cycle, is paused by turning bControlInput to FALSE, but resumes...
275
I'm trying to build my Classic Step 7 programming skills this weekend. I get stuck on little things that are not covered in YouTube tutorials. I'm...
333
I have a program that does a 7 second "scan" sensor calibration routine whenever a setting (setting is called assistance level or "AL" and ranges...
226
