Simple but work well
Guest
Guest
G
Dear all Plc Tutors,
May I share some simple plc circuit .
Normally this machine use 32 toggle switches to control by relays.
for example Sw. no.1 machine run in Speed A. tool No.1
Sw. no.2 machine run in Speed A. tool No.2
Sw. no.3 machine run in Speed A. tool No.3..
...............etc for 4 speeds and 6 tools.
The Last Sw. no.32 machine run in Speed D. tool No.6
When I use plc control (Mitsu) ..I use all those toggles sw.
at the output of PLC. and write program Sequencial funtion chart
for diff. 32 fungtion(may be can call 32 subroutines).
Yes..still work well for more than 6 years with the same fungtion
that user familiar with.
Anyway...Could you please give some idia about AB plc with thumwheel sw.in this case.
Thanks you very much.
platootod
Hello again..trying something on an existing poorly written program and just wanted to double check something system is an A-B MicroLogix 1200 In...
173
Hi all, Writng a FB in ST on Beckhoff TC for a pulser which turns on and off on a cycle, is paused by turning bControlInput to FALSE, but resumes...
260
I'm trying to build my Classic Step 7 programming skills this weekend. I get stuck on little things that are not covered in YouTube tutorials. I'm...
319
I have a program that does a 7 second "scan" sensor calibration routine whenever a setting (setting is called assistance level or "AL" and ranges...
215
Hi all, I have a simple question that I have overcomplicated and gotten stuck on. I have a variable, we can call it "light" that I need to stay...
321
