simple math
newguru
Feb 2007
virginia
Guys I'm sure this is simple, its just not for me.
if an i/p is calibrated for 10-50ma input equals 6-50psi out. what is the out at 25ma?
What is the formula to get this?
Thanks in advance,
Jason
22.5 PSI
(( Current Value - 10 ma) / ( Max Current Value - Min Current Value)) x ( Max Output - Min Output) + 6 = Output
(( 25ma - 10ma) / ( 50ma - 10ma)) x ( 50 - 6) + 6 = Output
(( 15ma) / (40ma)) x (44psi)) + 6psi = output
(.375 x 44) + 6 = 22.5
tutu types faster then I do.
See attached for a handy tool
newguru said:
thanks, for the quick reply. Mickey the scaling chart is exactly what I needed.
Your welcome. The chart is not mine, I dowloaded it from this site. I'm not sure who gets the credit. Maybe he/she will check in and take a bow.
That's me. Check the Excel file properties.
I use it for calibration checking charts when I have the techs install instruments. What is handy is the PLC counts. If you are looking at the raw value in a register just check the chart. Or don't have a MA meter but have a voltmeter to check the loop and it has a 250 ohm resistor check volts in the chart. I carry a pencil type VOM and a 250 ohm resistor for quick checks. I also have a version of the Excel chart running on my pocket PC.
hey Guys, I want to take my five counters, add them and multiple by 10, I got it to work, but WAY to many lines. Any suggestions...
1,791
Hi everyone, I am having a little problem verifying some math results being done in DL06. Doing simple math in DL06 suppose to be relatively...
4,733
Hello again..trying something on an existing poorly written program and just wanted to double check something system is an A-B MicroLogix 1200 In...
173
Hi all, Writng a FB in ST on Beckhoff TC for a pulser which turns on and off on a cycle, is paused by turning bControlInput to FALSE, but resumes...
260
I'm trying to build my Classic Step 7 programming skills this weekend. I get stuck on little things that are not covered in YouTube tutorials. I'm...
320
