Simple Omron timer question
Jan 2008
Ontario
161
Currently programming an Omron PLC and using a few timers. Just need to know something simple...
Since omron doesn't have a timer timing(TT) bit like AB, you have to check if the timer is timing like so: if NOT TIM001
which means, if the timer is not done, which would mean that it's timing....
but i'm wondering will that also be true if the timer ISN'T timing? Like if the timer hasn't even been executed yet?
AB has TT and the DN bit, with OMRON I can only check if the DN bit is on or off?
IE in Omron: AN TIMER001 OTE OUT1
I would want this code to only energize OUT1 when TIMER 001 is timing, but would it also turn on OUT1 when TIMER 001 hasn't even been started yet?
If you want to know if the timer runniing.Like Ebable bit in AB
Put another bit in parallel with the timet.
Its will look like that.
Ld(timer start condition)Tim 1 #10
Ld(timer start condition)out(bit 0)
LD To Out(timer done)
You can build the same bits with logic.
Having difficulty attaching image.
Will try again.
Helps when you read ALL the instructions!
Here you go:
Hello all, I am brand new to this stuff and have no clue what to do. I was asked to write a program to run a pulse signal and solenoids on an...
2,320
Hi..Is there a Pdf tutorial for programming the Ommron NJ CPU and NA HMI, perhaps to run a Omnuc G5 servo? Is there any manual related to...
3,691
I have one OMRON CJ PLC with EIP21 card, another CJ PLC with ETN21 card. I want then talk to each other using FINS(RECV, SEND..). OMRON pdf file...
3,737
I need to program a 5 input fifo system for material transfer. One input fires valves and vacuum and the next ones line up and go fifo in order...
5,004
First, my jab - simple communications unit - yeah right. That must mean that it is simple - as in simpleton, not simple to use. Point: I am using...
5,161
